Hi I have a 72 volt controller from http://www.theebikemotor.com . Its lable says 72V and 35amps +/-1. It came with a 1500 watt hub motor build. I've found the low voltage cut off to be 63.0Volts. I've run it at 18S LiPo which gives 75.6Volts peak and 61 km/hr max on flat level ground. What is the maximum Voltage and if I exceed it will it destroy the controller? I've attempted to contact Sunrise Intl but no response and nothing in the manual. Thanks!
