Phantom_KNA
🧲 New user
Hi everyone,
I’m planning a custom battery DIY project for my electric motorcycle and wanted to share my setup to get your feedback, advice, or any tips before I start ordering the parts.
Currently, here in Mexico, commercial 72V 20Ah Lithium-Ion packs are available for my budget, but I’ve decided it’s much better to import high-quality cells and build a custom pack with more capacity and better cycle life.
Project Goals & Bike Specs:
Thanks in advance!
- Vehicle: Electric motorcycle with a stock 72V Lead-Acid controller.
- Target Capacity: 50Ah.
- Chemistry: LiFePO4 (looking at prismatic cells like EVE LF50K or similar, Grado A).
- Cell Configuration (23S instead of 24S): Since the stock lead-acid controller handles a maximum float voltage of around 86.4V, a standard 24S LiFePO4 pack charged at 87.6V ($24 \times 3.65\text{V}$) might sit too close to the controller’s Overvoltage Protection (OVP) limit. To play it safe and protect the electronics, I am choosing a 23S configuration. This gives me a nominal voltage of 73.6V and a safe peak fully-charged voltage of 83.95V.
- BMS: I will be using a JK Smart BMS (8S-24S). I chose this because of its integrated active balancing (0.6A/1A/2A), which is essential for managing large 50Ah cells efficiently. I will program it via the app specifically for the 23S cell count and fine-tune the cut-off voltages.
- Discharge Rate: The 50Ah cells are rated for 3C continuous discharge (150A), while my stock controller rarely pulls more than 30A–45A on peak acceleration. The cells should run very cool and relaxed.
- For a motorcycle application subject to vibrations, what is your preferred method for compression and cell insulation (acrylic sheets, fiber tape, etc.)?
- Do you foresee any issues with the stock lead-acid controller low-voltage cutoff? (It usually cuts off around 63V, which means it will stop the bike at around 2.73V per cell—acting as an extra safety margin before the BMS triggers LVC).
- Any specific recommendations for a reliable charger matching this 23S configuration (~84V max)?
Thanks in advance!
