BatteryManTakeMeByTh
⚡ Regular
Basically title. I've heard Daly is either crappy or at least very hit or miss. I did hear good things around about the ones below:
batteryhookup.com
batteryhookup.com
Any feedback on these would be great, as would any recommendations. I'm new to the choices of picking BMSs, and I haven't found many sources out there that look legit. Happy to answer follow-up questions.
7s-21s 300a Lithium Ion / Lifepo4 Smart BMS + Bluetooth
These BMS units are brand new and work for all variations from 7s to 21s and everything in between. This BMS is rated for 300a continuous. These come with the bluetooth already installed. Included is 4x 4AWG wires with ring terminals already crimped. This makes installation even easier for you...
batteryhookup.com
8-24s 200a Li-Ion Lifepo4 BMS + UART + RS485 + CAN
This is the best BMS that works for lithium ion and lifepo4 batteries from 8s to 24s. So 24-72v lifepo4 and 28-86v lithium ion. It is preprogrammed for lifepo4 settings but you can change that. It has all the communications to work with inverters including UART, RS485, and CAN. Bolts are...
batteryhookup.com
