torker
Ah the genius of ES, So true.. And good you take the advice. So many ask and then don't. The insight posted by Cellman is spot on ... A slower wind in DD will "rock" on 72 volts @ 22.5 in. diam. My builds are old,low tech,on a budget . My 2810 in a 20 in. wheel with a soldered shunt @ 50 amps and 60 volts is a blast to 25 mph. Definitely put me right on my ass the first time I goosed it good 8) Ready to see some updates. Even at 72 volts if you keep the amps down it should live. Good luck.. Oops I forget it is a gear motor..
48 volt would still be over 50 volts hot and good speed on a 6t.. Time to go to bed
