The motor and controller in question came off of a Bullshittii (Busettii) ebike that my neighbor bought new several years back (I wish he had talked to me before he did! I don't even want to mention how much he paid). I believe this motor was rated at 350W but the motor is labeled with a Bullshittii specific part number so I'm not sure.
He barely rode the bike because it was a total POS even new then the shittii battery went bad, so it sat in his shed since 2012-ish.
Recently he gave the bike to me so I figured I'd try to see if I could get it to work with a new battery. I swapped the battery connector to match the good battery and it spun up the poorly-laced wheel on the stand just fine, so I taped the battery to the rear rack and geared up for a test ride. I made it about 2 feet before the the wheel fell off because the axle spun in the dropouts. :lol:
Unfortunately it also spun the tabbed washer on the axle on the disk brake side which damaged the axle threads in that spot. However, I still wanted to test it out to see if the electrics might be worth saving, so I pulled off the ruined tabbed washer and temporarily ghetto-installed a Grin V2 torque arm that I recently bought for my fatbike project (that I'll start a build thread about later) and I geared up again. The motor held on this time and amazingly, with a half-charged 48V battery and the 48V 25A rated controller, the POS bike made it up to 20mph (GPS). It was sketchy as hell at that speed, but I was still grinning like an idiot!
So naturally... I had to fully charge and rig up my stout 52V battery to see if I could blow something up or crash trying. :lol:
I was shocked to find that not only did the little motor handle way more than it should, but on the full charge it held 25mph! I ended up riding, amusingly terrified, at over 20mph without pedaling for the better part of 12 miles before I got home and realized that a rear spoke had snapped somewhere along the way.
I called that a lucky success and put it away.
This morning I pulled the electrics (and my torque arm) from the POS bike and opened up the motor. Much to my surprise, it looked very good inside as far as I can tell, so I put it back together. Unfortunately while removing the inner nut on the disk side, I had damaged its threads when I backed it out over the damaged axle threads. The outer nut was already damaged from earlier. Neither of those hurt the axle threads further, so obviously the axle is a lot harder than the nuts. I un-laced the bent POS rim from the motor and inspected its spoke holes. They are ever so slightly ovaled, possibly because the spokes were too small from the start (good job Bullshittii).
So, my thoughts are as follows... tell me if I'm not thinking straight:
If a die is run through the damaged part of the axle to remove the buggered threads and the two nuts are replaced, then this motor should be okay to re-lace into a good rim with proper sized spokes, if the slightly ovaled holes won't cause problems (will they?), and the tabbed washer can be skipped if a torque arm is used on the outside.
The controller label is half missing/unreadable so I'm not sure what controller it is, but I can see its rated for 48V and puts out 25A. It didn't miss a beat during my thrill ride so I'm assuming it's worth using again. However, I don't think that motor would last too long with that controller so I might use that my 20" folding bike with an appropriate motor for that (maybe a Mac 8T... the bike does have 135mm dropouts).
I really don't know what to do with the motor, but if it can be used after something as simple as cleaning up some threads and new hardware, then I'd hate to throw it out with the rest of the Bullshittii bike because it works beautifully in brilliant silence, and it impressed the hell out of me.
Let me know what you think.
I'll load up some pics in the follwing post(s).
