Erogo
There's no way you can get enough volume of air in through the size of tube you could drill down an axle, to do any sort of cooling worth bothering with.
But, as has been discussed in other threads on this topic, squirting water through that tube, and allowing it to exit as steam, would carry a lot of heat away.
Your objections:
a) water inside my motor is a bad idea for the electricities, and
b) water inside my motor is a bad idea for the limescale build up
are
a) invalid in a brushless motor, which would run ok completely underwater, and
b) valid, but solved by using distilled water.
E
Your objections:
are
E
