Doctorbass
You must remember that cell... the 18650V
I just want to confirm you guys that the famous cell i've been talking about on many post here that are in the Makita cordless tool and bionx PL350 ebike kit DOES NOT NEED BALANCING ! and that the imbalance after 300 cycles is only 0.2%
I've been looking for data over the internet about the sony 18650V cell and that's what i found.
In my case, instead of discharging them to 2.5V, i prefer 3.0V cutoff. that preserve the cell for 100+ more cycles, and you only sool e like 50mah.
Even though, i would recommand to use a LVC circuit to detect the first to reach the 3.0V. it's not recommanded in the specs, but i'm sure it would help to preserve them!
I also learned that they have theirt own heat protection inside that cut the current if the tab temp get too hot.. like if you solder directly on the tabs for too much time, you will hear a "tic".. and the cell will measure 0.00V (the thermal fuse would have blow)... that's a great news cause that indicate they are safer.. but you can anyway draw 16A or 19A pulse even if they reach 60 degree C max.
here is the list of all post about that great cell.
http://endless-sphere.com/forums/viewtopic.php?f=14&t=2764&p=52947&hilit=18650v#p52947
http://endless-sphere.com/forums/viewtopic.php?f=14&t=2638&hilit=18650v
http://endless-sphere.com/forums/viewtopic.php?f=14&t=4058&p=60146&hilit=konion#p60146
http://endless-sphere.com/forums/viewtopic.php?f=14&t=2764&hilit=+konion
http://endless-sphere.com/forums/viewtopic.php?f=14&t=2619&hilit=+konion
Doc
Doc
