markz
100 TW
So far this is all I can find.
Adaptto, Kelly, and Sabvoton are the three best best places to start looking for big power.
Lyens Xie-Chang controller (Also wrongly nick-named Infineon) Trapazoidal Waveform, Programmable.
eBay seller e-crazyman
Sevcon - Very hard to program. $1000 edit: Looks like its a varied experience to program.
Here is a link
Sabvoton
DIY Controllers - Lebowski
Greentime
Powervelocity.com
Adaptto $500 - $750 lots of extras available (BMS, Charging Coil) master/slave configuration available. $650-$950(CAD).
Kelly controllers are programmable! They have Sine wave controllers too.
https://endless-sphere.com/forums/viewtopic.php?f=3&t=74362&p=1163566&hilit=Programmable+Kelly#p1163566
weight and form factor are an issue. Link
https://endless-sphere.com/forums/viewtopic.php?f=2&t=84970&p=1242598&hilit=MXUS+Kelly#p1242598
Kelly has FOC KLS-S
and the controller (being the smallest of the whole series) is BIG as well
eBay seller HKSunwin is unknown
Grinfineon Controllers from Grintech at ebikes.ca
From http://www.ebikes.ca/product-info/grinfineon.html
Looks like their FOC unit is programmable.
https://endless-sphere.com/forums/viewtopic.php?f=31&t=65031#p976242
Here is a link
Sabvoton
Greentime
Powervelocity.com
Kelly has FOC KLS-S
the wire looks like a #8-10awg. well done kelly! con: they are very stiff and not fine stranded, so hard to bend. but that is only an issue during install.
so it seems you really HAVE to buy this z-tek usb/serial converter.
<----This statement makes me sold on a Kelly.
new kellys KLS CAN do variable regen
Can I Reprogram the Controller Settings?
Unfortunately not, for reasons outside of our control these boards are not available to us in a way that is compatible with parameter designer software to change the settings. However, all the regular settings (low voltage cutoff, current limit, throttle auto-cruise and ramping etc) and much more can easily be done via the Cycle Analyst.
This is definitely not a controller build intended for multi kW power levels, but for for stuff in the 1kW range it is quite well suited.
