recumpence
1 GW
AussieJester said:I wonder if i could make me another
pulley using the epoxy glue method i used on the 5mm pitch pulley i made MAtt? I don't see any
reason why not...
KiM
I don't see any reason why not, either.
Matt
reason why not...
KiM
Sweet!recumpence said:This is the only ratio I am willing to make. It is EXTREMLY expensive to prototype large pulleys like this. This pulley is 8 inches in diameter. That is the max the pulley shop can get out of their normal material (8 inch round bar). So, the 3.07 to 1 ratio is the lowest it can go.
I wish I could go with more reduction. But, this is the best we can do.
http://www.pfeiferindustries.com/contact.htmBourn & Koch CNC Gear Hobbing
~Hobs and tooth ranges currently available
* 5mm HTD, (17 Tooth through 200 Tooth)
* 5mm PowerGrip GT, (16 Tooth through 200 Tooth)
* 8mm HTD, (14 Tooth through 140 Tooth)
* 8mm PowerGrip GT2, (22 Tooth through 140 Tooth)
* 8mm PolyChain GT, (14 Tooth through 140 Tooth)
* Additional hobs available upon request
Pfeifer Industries, LLC.
2180 Corporate Lane
Suite 104
Naperville, IL 60563
(630) 596-9000
info@pfeiferindustries.com
E-racer said:You could always stack a set of water jetted plates, much like a stator is constructed. Then you can just use one plate as the hub. 1/8 plate is cheap or you could go plastic (maybe aluminum hub and the rest of the plates plastic :-D).
recumpence said:This is Ben's bike.
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=15233&start=390
I have ridden the trike a few miles. It is nearly totally silent. Under acceleration, you can hear the motor whine. But, when up to speed, all you hear is wind and a tiny bit of belt sound. It is very cool! It runs sooooo smooth. I am very happy with it. I am also happy with the Sprague one-way rather than a freewheel.
I do have a video of it. I need to upload it to youtube so I can link it here.
Matt
That design could be tweaked. You could also run a hub to get w/e offset you want. I cant argue though I love nice CNC pieces to!recumpence said:That is still not nearly enough offset however. The pulley actually needs to be dished to the side quite a bit.
Kurt said:That torque arm from the reduction drive to the rear drop-out. I take it there is a bearing on the jack shaft end hard to see from the pics?
Kurt.
recumpence said:The only "Problem" I am having with it is front brake rotor vibrating. I have tried many cures. ...Matt
