Warren said:
I see, over on the BROL site, you mention you have progressive regen brake levers!
https://www.aliexpress.us/item/2255801069583075.html?gatewayAdapt=glo2usa4itemAdapt&
Could be useful, but the page doesn't have much in the way of operational details.
I'm still looking around for other sellers of the same thing that may have more info, but AE's search is worse than amazon's, and that'sreally saying something.
A google search finds Flipsky's page
https://flipsky.net/products/brake-handle-aluminium-electric-scooter-brake-handle-clutch-lever-replacement-for-max-g30-parts
but it doesn't have any more info, it is exactly the same as on the AE page.
I don't suppose anyone that has used them might know how much travel they have for the full output voltage range of the sensor, and what that voltage range is?
It matters for systems that use them to pull a cable-actuated brake as well, so the regen actuates and either completes before or has minimal overlap with the start of the cable actuation, so maximum use can be made of the regen, (but also has the widest possible travel to use for the regen for easy use of it). If the sensored-travel is adjustable, even better.
The pictures they have don't seem to all show the same design, either. The first one shows a lever with a threaded tube sticking out of where the cable would enter (but the threaded tube has no way to grip it to use it as a tension adjuster). The third pic also a plan view of the same side has a different housing with a plastic "bump" at that spot and nothing else, no adjuster or apparent ability to hold one--the same is shown in the fourth pic that is an oblique view from the direction of that cable entrance, and the same is also shown on the plan view of the other side in the fifth picture. .
Right now I'm using a regular ebrake lever with a switch, and a cable-operated-throttle unit pulled by that lever, plus a couple of relays, to control braking of a grinfineon via the Cycle Analyst. (later this will control a couple of Lebowski-brained powerstages directly). It's reliable and so far waterproof, but larger and more cumbersome than a lever designed for the purpose with the sensor built into it, and it means the cable can only pull the sensor and not a physical brake.
Ebike Brake Lever Handle brake with Hall Aluminum Alloy lever Handlebar ADC Control Electric Scooter/Electric bike MAX G30/Ebike
Weight: 150G
Material: Aluminum
Packing: OPP
Description: Original quality, original MAX universal replacement parts, applicable model: MAX G30, suitable for VESC series ESC ADC control
Socket: ZH1.5MM 3P female
Size: 16cm*9cm Weight: 150G Material: Aluminum Packing: OPP Description: Original quality, original MAX universal replacement parts, applicable model: MAX G30, suitable for VESC series ESC ADC control Socket: ZH1.5MM 3P female
Weight: 150G
Material: Aluminum
Packing: OPP
