A123 1100mAh batteries in the Black&Decker VPX packs!
Doctorbass
Quebec, Canada East
i still say dewalts all the way; those wouldn't be bad maybe in rc car/plane.. ebikes ..nah..
Yah, it'd take a ridiculous number of those cells to make a useable ebike pack. Who'd want to spend all the time it takes to solder together hundreds of them? :wink:
Now if they we're a lot cheaper per amp-hour....but unfortunately, they're not.
Some deranged type with a... LiFe-wish?
Yesa-battery said:
18650 cell for Laptop battery these small battery maybe OK, but for E-bike/scooter maybe hard work to have a larger capacity.
No sh*t?! :D
These might be okay to shore up a sagging cell in a larger pack. Easier than disassembling and rebuild the whole pack -- just solder one of these on the side.
Richard
Even in a laptop is there any benefit? I mean compared with a cheaper regular 18650 cell? There's not much of a peak draw I wouldn't imagine.
Yep, this is going the wrong direction, size-wise. What we need is to get ahold of the larger 32138 and 32156 series cells that a123 is doing for the Volt and for plug-in hybrids. Not much chance of that unless B&D/DeWalt decide to do some new mega-power tools. :)
-- Gary
I can get these for $14.50 each after tax from my local B&D outlet store. They come with a two year warranty.
Anyone want to speculate if the warranted factory package will allow high discharge rates? If it does, am I crazy for thinking about wiring up a rack for a few dozen of them?
I wonder how quickly the factory chargers take to top them off?
How does one figure watt hours?
I get $14.5/(1.1Ah)(6V)= $2.20/watt hour. Dewalt 123 cells are $11/(2.3Ah)(3V)=$1.60/watt hour.
Oh, you meant for two. I thought you meant $14.50 per cell. Still expensive though... on e-bay you can sometimes find the DeWalt packs for $100-120 each which is $10-12 per cell, or $1.32 - $1.58 per watt-hour. Those cells (the 26650) are 3.3V 2.3Ah which is 7.6 watt-hours. These smaller ones are 3.3V 1.1 Ah which is 3.6 watt-hours.
^Yes, you're right. The only way these would be useful is in a high voltage short range situation such as a dragster. I could make a 120 volt pack for $290 vs $440 for the larger A123 cells. As soon as you need more than the 1.1A per cell, you may as well use the 2.3A cells instead.
