oatnet
999zip999 said:Oatnet what amps can the 4 rod aliumun block drutludge build safely carry ? Hopefully 65amps ? Crimping has a lot of surface area.
65 amps based on a large amount of clamping area should be fine, but the clamp needs to start very close to the top of the cell body. If you rolled up the tab across its width, it would make a pretty thin wire, so you want this part to be as short as possible.
The cross-section of the tab - width x thickness - is the choke point of current carrying ability, so all you really need is a contact patch as small as that cross section. A larger contact patch buys time as it means the join would have to really degrade before it becomes the choke point, and helps pull thermal load off the tab material.
However, If you look at the drutledge pic below, I have concerns arround the bare tabs underneath the clamping blacks. First, vibration of the clamping block assembly will eventually stress crack the tab material, which is carrying that mass. Second, it looks like one could push the clamping assembly down or to either end of the pack, and cause the tabs to short out against each other or the cell body. Third, the distance between the clamping block and the cell tops leaves a lot of tab material to carry the current, sorta like leaving long FET legs, so I would be concerned at higher discharge levels.
Moving the blocks close to the cell body would eliminate concerns 2 and 3. It would require punching holes in the tab material which does absolutely nothing to reduce the cross section I mentioned, or reduce the tab's current carrying ability. However, I don't have a good suggestion for supporting the clamping block's mass, and I am not a fan of the weight it adds to the pack, so while I considered it I never implemented any designs along this line.
-JD
