I'm looking for an opinion on these cells, hoping to build a battery big enough for an 8kw hub motor
All my builds use these A123 cells.
They are simply the best thing available if you need high discharge, long life and safety at the same time. Perfect for a high power daily.
I just can't seem to find anything better yet.
Only drawback is they have a low ratio weight/size/capacity, so it's not the best choice for long range.
They start showing some significant voltage sag above 500A, but it doesn't seem to damage them much. I'd say the practial maximum for a 24S 2P is around 500-600A. Above this the voltage sag starts becoming too high.
So far I own three 24S packs (one is 1P the other two are 2P) and I converted a few friends to use these as well, no one ever complained
They are used on powerful setups, so they get some severe beatings.
I had a few cells gone bad because of some physical damage (the pack got smashed during delivery). Got em replaced, apparently the tabs can be soldered with regular solder, at least that's how the repair shop did it on mine, so there seems to be no actual need for a laser welder. Other than this I never had any issue with them, they seem pretty much bulletproof. My motorcycle's pack has been manufactured in 2012, I got it second hand, installed it in 2018 and it's still kicking ass, delivering 400-500A everyday.
