Ktraughb said:
wb9k said:
Think about this---if one cell fails in the 11P pack what are the consequences? Compare this to a single cell failure in any 1P pack.
True, but if one cell fails it will have to be de-soldered, replaced and balanced and re-soldered into the pack. Would a fresh cell affect the overall stability of an individual pack?
Your options depend on a number of things. Most times, cell "failure" (which is relatively rare to begin with) is not a catastrophic problem, but the development of an undesirable behavior (like excessive self-discharge). In those cases, whether or not this even becomes noticeable depends on mostly the frequency with which a battery is used. If used often and charged with a BMS, you may never even notice anything at all. It's more a case of a "dud" in the bunch, but because it's (in this case) less than 10% of the total cell group, the other 90% of cells that are still OK can pick up the slack unless the problem is severe, which it rarely is. These Hymotion modules we are talking about have been in storage for a couple years by the time they are pulled out and tested. If problems like HSD exist in the module, the cell group will already be dead and the module scrapped. The chances of you having this problem with these batteries are consequently very low.
Let's say that somehow a really severe problem develops with a cell and you are able to figure out who the culprit is (not always easy without a good quality meter, mind you). Cell replacement in these modules is not really possible because of their design. You can, however, easily use a dremel tool to carefully cut one of the weld straps to isolate a problem cell. Then you'll have the same pack, but with a little less capacity and a little less power capability. For your application, the battery would continue to perform acceptably. Re-(top)balance the pack and continue on your way. You
could replace the cell, but you would have to resort to some pretty ghetto techniques, which doesn't seem to be your style (and good on you for that.)
Keep in mind that I work in warranty, so I see pretty much everything that breaks. My head is always looking at what can go wrong, and planning for those events. My experience with the Hymotion packs and modules (and I have a lot of it) says that these modules are in all likelihood going to give you years of trouble-free performance, and they are as easy to care for as it gets. I don't use a BMS on any of my Hymotion packs, opting instead for the kind of techniques that Arkmundi describes in this thread. This is not for everyone (and certainly not for lipo), but if you control your processes intelligently and are vigilant in overall pack supervision (mostly during charging), all should be just fine. The Hymotion module in my audio system probably sees near to 100 cycles per year. I balance it once or twice a year. It doesn't need any more than that. All charging happens right on the audio rack. The 26650 packs I use in my lawnmower and other devices run about the same, with the same type of pack management techniques.
Hope that helps.
