deVries
agniusm said:Here is the second video (being uploaded at the moment):
The video is still not available??? Maybe your upload connection failed? :?
deVries said:agniusm said:Here is the second video (being uploaded at the moment):
ohzee said:Here's the eva BMS on 24s figured id share. This is just temp to test still need to figure out what the final product is going to look like. This BMS is pretty large compared to the signalab. Hopefully it works out good time will tell.
Need to apply some load then let the BMS charge/balance to see how it works.
The BMS I ordered from evassemble was custom. It's 24s 100a 150a max.
Thought i would extend voltage upward with more volts now and less amps with 2 x bms, but not sure now bms's will work without all cell positions in use, i'm being informed, eg18S won't work on the 20S board, doesn't sound right can you confirm?
deVries said:Agniusm has these available on sale again. Order before August 13th to get a kit. He only does small production runs, so you might have to wait a long time between runs. Order now if possible to avoid long waits.
Links: Main Info Here
For Sale Thread A123 AMP20M1HD-A Battery pack kit
docnjoj said:OK I just dropped one too many little screws and ordered a box of 100 3mmx12 socket head stainless. These were about 4 bucks but 10 to ship them by the least costly way from UPS. BoltDepot is a really good place to order from since my last batch of the button head bolts were about the same cost. So I got spares and if you need a few let me know. I, however, do not want to get into the bolt business so try to do a better job than I do at finding bolts that you drop!
otherDoc who used to have the hands of a surgeon, honest! Not these days
Oh yeah! Since I'm a glutton for punishment I am thinking about ordering another 6S kit from agniusm. I have 2 extra cells and could probably buy 4 or 5 more fairly reasonable. That would give me 18S and more speed than I can handle! Hmmmmmmmmm.....................
[/quote]Sounds like hunger for speed, mmm...I need something faster myself as my Meduza scooter does 32kph tops. Have HS3450 + 24S cells and all bits, need to figure out what to build next "out of this world" Hows your second kit doing?
whatever said:agnesium you get about 9mins at 75amp in the video? is that correct? cut off voltage 2.7v ?
docnjoj said:Well done with my second 6S pack except for the details. I was a bit more difficult than I planned afer doing pretty well because my nailpolish failed on one trace and when it hit a tab, poof. So I soldered a jumper in and it works fine .All cells locked in place and show up fine on the Cell log.. Now to charge it with the new Meanwell powering the Hyperion. woo who!
otherDoc
