hillyterrain
So much good info, again! I was close to deciding between em3ev and ping, but now I'm swinging back to LiPo like a pendulum .. However I read on other posts that the discharge rate for the HobbyKing cells are highly inflated..
etriker, I would love to have more info about your A123 assembly, do you leave those 3cell BMS on, and how do the balancing leads work, what charger do you use and how often do you balance charge?
Are there standard fireproof lipo bags out there or do I just have to build my own?
It's a 48V motor, using two 22.2V hobbyking will give me 44.4V nominal, probably even less in real life (48V packs are usually 50V nominal), will I feel that difference?
How fast will I cycle through the LiPo if I use them every single day?
