chvidgov.bc.ca
This is my Actionbent T1 alloy tadpole trike, aquired by mail from Redmond Washington for 1200 dollars Cdn. in December 2010. I assembled it out of the box it came in, and made a considerable number of modifications to the bike, to add a rear 2806 Nine-Continent motor to the trike.
Some of the features of the vehicle include:
Alloy. They mistakenly sent me alloy instead of cromolly but I kept it, but overcompensated on the dropout torque support.
Dual Ping batteries mounted in cutaway steel pannier baskets low under the seat. Baskets pipe clamped to frame on the sides, and to the seat on the front of each one. Can run one or two in parallel depending on range.
Dual disk brakes are stock (Tektro IO) - quite good. I like the friction shifters - they worked easily with the replacement 7 tooth freewheel (I found a Megarange yayyy!)
Dual rear torque arms on both side, consisting of one Amped bikes arm and one from ebikes.ca, on each side.
Pings (48V 15ahr, connected in parallel with ideal diode from Tiberius (Nick) on ES) held in place with self-adhering Velcro into the baskets, inside Plano 1412 marine tackle boxes. Yellow foam inside, except around the BMS. I open the lids while charging.
Replaced original idler with Terracycle idler
Replaced stems with new BMX stems to enable fore-aft adjustability of the handlebars.
Equiped with Veloamp amplifier from ebikes.ca and twin Westmarine waterproof marine speakers (50w per channel). Driven from mp3 player on boom.
Granite gear pack add-on pack under boom.
900 lumen Spiderfire flashlight from DealExtreme. Very bright.
CycleAnalyst standalone model, with 12 mosfet BMS sensorless controller - total output of dual Pings approx 1400 watts. I like these controllers, they will start up from essentially zero, with no Halls, and are quite powerful for the money. No CA connection though - used the standalone model.
Marathon Racer tires on the front 406 sized.
Modified Mirrycle mirrors to support the fenders, by adding extra arm piece to each Mirrycle.
Mesh seat with strapped on Thermorest for winter riding. Nice and warm and very plush. Can remove for summer riding.
Axiom Dutch shopper bags with Arkel tail pack.
Lots of flags for visibility. Flag from PurpleSky.com
Here you can see the two torque arms. The dropouts were very shallow and being alloy need a lot of support to immobilize the motor axle in the dropout so as not to strip them. The arms on each side are opposed, and attached to either the frame with a pipe clamp or via a short piece of steel from the end of the arm up to the seat stay attachments. The dropouts were only 130mm apart so I had to file down the axle shoulder a fair bit so as to get washers inside the dropouts, with only about 2mm of stretch of the frame on each side, which was deemed to be possible after considerable consultation. It took about one week to fashion the rear end. It has been rock solid after two months of riding, around 1200 miles with a couple of substantial hits to the wheel. I'm running 26 by 2.0 BigApple on the rear tire to cushion the wheel (and me).
The ping battery boxes more or less snap right in to the baskets, and are held in the basket with one piece of self-adhering velcro. Right behind the cruciform and down low is the best place for the batteries. I had them on the rack for a while but broke the rack eventually, and experienced minor pedal steer, brake steer, and even shimmy. Moving them fixed those issues, although I still have o-rings inside my headsets, which I put it, to dampen the steering a bit. My toe-in is set to zero which seems to be ideal. I notice the 9C spokes loosen up now and then so I do have to tighten them occasionally.
The bike is an insanely fun ride, and great for cruising up to eighty miles on weekends on moderately hilly terrain around Victoria. It is fine in traffic around 30mph, and is a bit stealth in case the cops wonder how a bike can go that fast.
I keep trying to think up other gear to add, but I can't so I will just ride! Maybe a GPS.
