Any?flippy said:can have a charger you can set to any voltage.
john61ct said:So what would you recommend as a cheap but good starting point for 2 - 5V?
Ideally 1000W range, but could make do with say 300 at a time if necessary?
… that chip is a comparator. try finding the main control IC, it might be on the bottom on some boards….
You misunderstood, not talking about cheap Chinese gear.flippy said:those buck converts wont sustain those loads for long, i have tried. they are actually only 5A or so.
Thosen are not "dirt cheap".john61ct said:You misunderstood, not talking about cheap Chinese gear.flippy said:those buck converts wont sustain those loads for long, i have tried. they are actually only 5A or so.
Artesyn, TDK, Lucent, Lambda, NTI, Astec
as used in telecom rack setups
They are if you're patient.flippy said:Those are not "dirt cheap".
check the datasheet. those 2 comparators are your target. they feed yes/no into the regulator chip. one is for current the other is for voltage.jelev_k said:Here I started to specify the electrical circuit.
The output voltage should be regulated by this chip UTC3845D. Unfortunately, It is totally unknown for me.
... DC-to-DC fixed-frequency current-mode control schemes, with a minimum number of external components.…
john61ct said:They are if you're patient.flippy said:Those are not "dirt cheap".
e.g. PAH100S48-5, lot of 100 for under $250 delivered
But even at $15-25 I call that dirt cheap, and you can get those or similar even just one at a time.
And can work within that, just keep under say 30Ah and buy more of them.flippy said:those buck converts wont sustain those loads for long, i have tried. they are actually only 5A or so.
john61ct said:I never understood that concept, at least for battery charging.
AFAIK, CC happens naturally, isn't even a function of the source's power regulation,
as long as C-rate is low and the battery depleted.
Soon as the HVC setpoint is reached, charging terminates, isolates from the 48V buss.
If there never is any CV charging going on, how can you say it isn't CC?
The PSU must be capable of non-hiccup-mode current regulation. most PSUs are not---they tend to be the type that just shutdown if they can't hold a constant voltage. Some recover once the load is removed, some don't until completely power-cycled.john61ct said:AFAIK, CC happens naturally, isn't even a function of the source's power regulation,
