monster
- Joined
- Jun 17, 2007
- Messages
- 1,411
i have a poorly designed disc brake caliper that has plastic where you screw clap the brake cable and it slowly slips through. as a consequence i am always re-adjusting my brakes.
is there an adjustable cable spacing device similar to the ones on the levers, but which you could put in the brake line? something that would give more range of adjust ability than just the lever spacers alone? it would be great if there was because the range of movement they give you in most brakes is rally small and you can spend ages fine tuning the brakes.
