Pajda said:
Most problems are related with the software.
What problems? Might I ask, friend? ? What software did you use?
There are other soft wares for viewing the data ( than the OEM)...
Which is useful for comparison of DCIR fade when you compare first and last cycle curve.
Easily done with the Pl series. Data every 1 second. I can look at the first cycle IR, scroll down the file.. and see the 100th cycle IR. Time, date, ect. You would not be able to do that with the OEM software, but Excell and/or Wordpad.. yeah you can. Or put it through another program like the .cba format. All the logged data can be exported to delimited text.
The export to text is quite handy as you can easily import the data into Excel for more detailed comparison and data overlays. The chart is created this way using the charting in Excel. Very useful.
I got all of this. One sheet. Plus I get to recycle my energy. Matters when you have 100,000Wh throughput. 1000w. 6s. Regen. I test big cells, I dont play with those wimpy 18650 or 21700. Seriously, how do you plan to test a 25, 30, or 60Ah cell with 10A discharger? 30w? 2C on a typical 185650? Stress test much?? I guess, if your biggest cell is 10Ah, you could do 1C. 95% of the usefull-to-me cells in the world are much larger.
DateTime SlaveNum Cycle Mode SupplyVolts LSupplyVolts SupplyAmps PWM SecTimer AvgCellVolts MaxCellVolts AvgIR FallBackVolts CVStarted SlowAmps AvgAmps FastAmps SetAmps AhrIN AhrOUT PackVolts AvgPackVolts Fuel1 SumError Cell1Volts Cell2Volts Cell3Volts Cell4Volts Cell5Volts Cell6Volts Cell7Volts Cell8Volts Cell9Volts Cell10Volts Cell11Volts Cell12Volts Cell13Volts Cell14Volts Cell15Volts Cell16Volts Cell1IR Cell2IR Cell3IR Cell4IR Cell5IR Cell6IR Cell7IR Cell8IR Cell9IR Cell10IR Cell11IR Cell12IR Cell13IR Cell14IR Cell15IR Cell16IR BP1PWM BP2PWM BP3PWM BP4PWM BP5PWM BP6PWM BP7PWM BP8PWM BP9
Measurement accuracy:
Voltage resolution: 78uV (16 bit)
Voltage tolerance: +/- 6mV
Charge current: +/- 1%
Capacity added to pack: +/- 1%
Percent capacity (“Fuel”): +/- 5%
Heat sink: Internal 120W aluminum, thin finned
9 position LCD: 2 line, 16 character, light grey/blue backlit
Size: 5.70" x 5.57" x 3.40"
Specs say it has better resolution than the EBC-X0510 one?
