lookinglikejesus
- Joined
- Mar 14, 2022
- Messages
- 26
Hi,
I've owned this 20s custom battery (made with boston power cells) for 3 years and it's older than that by a few years, I've only given it 180 cycles. I've never had issues with the battery itself, but last night the BMS cut off 3 times and after inspecting it noticed group 1 was at 4v, group 2 at 3.18v (is that big of a disparity even safe?) and the remaining 18 groups were all around the same balance 3.6ish. I'm using xiaolang blutooth BMS to find all this out and the voltage disparity score was 64 with a big red symbol when you first boot up the app, it showed .74. Guessing this was the voltage disparity.
Obviously this is an old battery, I'm mostly wondering is it safe to use. I've had another custom DIY battery have an 'incident' let's just say and I'm very weary of these. No shop would ever try to repair it nor do I because I lack the expertise, I'm wondering what the issue is (dead cells or just not charging right/unbalanced), and should I stop using the battery immediately? And I guess side question, safe vendors to by a replacement battery that I can trust?
