Well, a brushless motor is AC by definition. What you're talking about is an induction motor, vs a permanent magnet motor. The controller uses a full bridge to reverse the polarity of the output.
The controller for an induction motor is more expensive.
The motor itself, since it has no magnets, should theoretically be cheaper, but in scooter sizes, they are not.
One cool feature of an induction motor is the rpm is not really limited by the voltage like a permanent magnet motor. It's like having gears. The max rpm is limited by the rotor flying apart.
You can get an induction motor quite cheap on ebay or surplus, but wound for 120v or higher. 480v ones are very common.
I wouldn't be that hard to rewind one for a much lower voltage.
In theory, a permanent magnet motor will be more efficient because there is no slip. In larger sizes, an induction motor can exceed 95% eff.
I rode the GPR with the induction motor. Unfortunately, I was confined to a parking lot and couldn't really open it up. The low speed response is extremely smooth and the motor is very quiet. The motor was custom from Highperformace Golf Cars.
Here's a pic of the motor and the Curtis AC controller:
