Hillhater
100 TW
Definitely a generator not a motor ! ( no throttle controls or controller anywhere )
boy, ! that steering wheel is neat though !
and the gear shift on the fork stem !!
The man is totally out of his box, which is brave for a Japanese.Hillhater said:boy, ! that steering wheel is neat though !and the gear shift on the fork stem !!
alan c said:Hi Im really keen to give this a go . Dose anyone know if you could use an e bike sensorless controller instead of an rc one cheers![]()
:x This regen/capacitor puzzle is making me cat sh!t crazy…. I can't wait to buy an alternador to test my theories. Cheers for your input. I look forward to seeing you kick off your project!alan c said:Hi I dont think so. I could be wrong but i think the battery powers the field and the regulator regulates how many volts go in.If you by pass the regulato 8) r and run 12v direct to field you get the same amps but the faster you spin it the more volts .I have seen 250+ Cheers
Dee Jay said::? hold up one tooth-pickin-chicken minute...
An alternator & voltage regulator, when used in a car, feeds its own power to its own rotor coil immediately after the battery/starter turns the alternator/engine, does it not? The battery is used to store excess power for later use of the starter and electrical accessories.
Can the battery be bypassed? When slowing down in regen mode, is it possible to use just a quick excitation from the capacitor for the alternator to generate minimal volts, and in turn, could that power be fed back to excite the coil to generate higher voltages to be fed to the capacitor?
The capacitor will be used like a battery, the difference being, the cap powers the rotor coil for dead stop take off, instead of turning the alternator/engine like the battery does.
Is this power feedback feasible? If not, I'll have to use a separate battery pack to excite the coil for torque on demand...
lutach said:The actual translation for the title of that "Brasilian" man is:
Steering wheel bicycle with an alternator.
Alright! Another altermotorist! 8)Harold in CR said:You guys are not the only ones to be messing with Altermotors.
