John in CR
100 TW
So I'm building a bike out of 18650 batteries, and already have the strings soldered end to end. The plan was to roll them up in fiberglass cloth & epoxy. I've done the first 7p10s string, but fiberglass is a bit too flexy as a frame material. Sure I could go to an outer layer of carbon fiber, but can't source any locally, and I'm cheap.
Aluminum makes quite stiff frames, and at about a 3.5" diameter even very thin AL can be really stiff if you avoid the "beer can effect" and this will be solid core, so no beer can effect here. I was trying to plan how to make my roll up layer of glass nice and smooth anyway. Then I thought if I get one of those commercial rolls of aluminum foil, I could just roll the wet epoxy fiberglass log up in aluminum foil, say 6-8 turns thick, and it would add tremendous stiffness at that diameter. Plus that length would now be waterproof too. The AL wouldn't be the exterior layer, so I wouldn't have to worry about toughness of the AL foil, and I could just finish with a 2 turn layer of glass. The final glass layer would be starting on a nice smooth uniform surface, so no sanding beforehand, and still allow an easy smoothly finished result. Also, there would be no waiting for expensive and harder to work carbon fiber to arrive, though I will probably still need uni-directional carbon to make the strong end connections, but that's for later. I'll probably use these "batt tubes" in a different manner before building them into a frame anyway.
So what do you think, is aluminum foil used in this manner a good idea for an ebike construction material? If so, how thick should I go, since the solid filled fiberglass tubes will already be very strong and all I really want to do is add some stiffness? This also make construction even simpler, which is a nice plus for a lazy "easy way" type.
John
John
