kmxtornado
The bike I recently revived from 2011 uses V-brakes. I was thinking about disk brakes but finally decided it's not worth the money for me currently. The only reason I have concern now vs before is b/c I'm taking on my hills since moving and also I've overvolted it to run on 48v so it's got a bit more speed than it used to. I find that stopping from 20mph on flats already takes quite a bit of distance. I've tuned the existing brakes to be as good as they can be but looking to replace them with another set of mechanical v-brakes unless there are other budget options you may recommend.
I did consider switching to disk brakes, but the compatibility even with the various kits that allow me to attach a caliper may not have as much tolerance as I need. Watched several YouTube videos on the disk brake conversion and I'm worried the various measurements may not fit it well. I will not be riding on wet roads.
Any v-brakes you recommend? or perhaps just better performing pads?
