Spacey
Ok this is driving me round the bend. I bought one of the newer Capacitor based 16 Cell BMS from (won't mention company until I am certain I am not in the wrong) in the vain hope that this one would work as the last two just did not at all. This one worked for 6 mins then after disconnecting the controller (infineon) and re plugging in decided not to even power on the Cycle Analyst. The total voltage from the BMS was 51.3V but the main battery pack was 53.8V?
But when you apply any load to the "OUT-" of the BMS it just dies.
"B-" from the BMS is connected to battery pack Negative. "
"P-" from BMS is wired to charge in as per evessemble instructions. But I have found from this site http://www.ecitypower.com/download/...BMS Discharge and charge together Circuit.jpg that they like the load to be from "P-" with the "OUT-" not even wired up? Looking at the BMS wiring picture though it looks like their are 2 cells between each connection?
Now I have checked the BMS sensor wires and all is in order:
Sensor wire "0" goes to Cell 1 Negative and all the rest from Sensor wire 1 to 16 go to the positives on the cells from 1 to 16. Voltages go up in increments of 3.3V
So what the hell am I doing wrong, have been up 2 nights with this and is starting to make me think there is something wrong with me. The same thing has happened with the resistor based BMS from same place Model: AE-LBB16 REV A1
Here is the letter below that I have just written to them:
Dear *******
I am a very very unhappy man!
The AE-LMD17 REV A1 16 cell BMS balanced the pack fine whilst charging, although the highest cell hit 4.1v for a long time!
But.....It does not bloody work!! It worked for about 6 mins then not even enough power to light the Cycle Analyst. Voltage on "OUT-" is 51.7volts but voltage from battery is 53.8Volts, but if you attach any load to the "OUT-" on the BMS it just turns off!
I have wired the cells as below: Have checked volts on BMS Sensor wire from 0 to 16.
BMS Sensor 0: is wired to Cell 1 Negative
BMS Sensor 1: is wired to Cell 1 Positive 3.3V
BMS Sensor 2: is wired to Cell 2 Positive 6.6V
BMS Sensor 3: is wired to Cell 3 Positive 9.9V
BMS Sensor 4: is wired to Cell 4 Positive 13.2V.......
all the way up to ......
BMS Sensor 16: is wired to Cell 16 Positive 53.8Volts
Is the above the Correct wiring because something is not correct!
B- on the BMS is wired to Battery Pack Negative (Cell 1)
OUT- on the BMS is wired to Negative Load/controller out i.e Infineon controller
P- on the BMS is wired to Negative Charge in from Charger
What am I doing wrong? This is the 3rd BMS to go bad, the first two are AE-LBB16 REV A1 they do exactly the same!
The BMS from my Headway pack works just fine so does my Ping Signal Lab BMS, what is wrong with these 3 BMS's. Unless I have done something wrong I will be sending them back.
The capacitor BMS worked for a few mins, disconnected the controller (BMS still all wired up) then reconnected controller and nothing. There is a 2Volt difference between "OUT-" and "B-"
Could you please check that my connections are correct.
