I did find one that is dish-less and it actually does have a disc brake, the MXUS XF07.
Unfortunately, It's efficiency throughout the speed range is worse than most (if not all) non geared direct drives I have seen. Example below comparing to Leaf 35mm and Nine Continent 28mm:
Our ebike motor simulator allows you to easily simulate the different performance characteristics of different ebike setups - with a wide selection of hub motors modeled, and the ability to add custom batteries and controllers and set a wide variety of vehicle parameters you'll be able to see...
ebikes.ca
Really surprised to see that. Normally the geared hub loses to the non geared direct drive hub in peak efficiency but is much more efficient at low and mid speed. But this MXUS geared hub motor is worse at every speed than even a cheap old school Nine Continent 28mm wide stator non geared direct drive motor.
Go it if you can get it, you could spend many hours hunting for a better motor and come up empty handed.
I’m frugal and use what falls into my lap, so haven’t bought Aikemas, but have one that’s been in on and off use that would be pushing 15 y.o. on stock bearings and nylon gears, so pretty confident in their design, fabrication, and parts spec, not disposable junk.
