Teaker68
Finally had fat tire bike wheel built for 170mm dropouts. Was able to remove spacer line up disc brake that still needs some fine tuning.
I know I was going to have to customize a few things but I don't know now if this set up is even going to work. As you can see from picture bike is upside down with 1/2" clearance from gear sided stay and 1 1/4" from disc brake sided stay. Haven't tested derailleur or chain yet for the fact being know once tire is mounted its going to rub. I can put jamb nut and spacers to increase current dropouts 170mm but this wheel was supposed to be specked out for 170mm.
Appreciate any feedback.
