Don't bother taking things apart. Pointless.
A few minutes with Google shows your bike uses two sensors: RPM and torque - not unusual.
EBCO bike spec said:
Electric Drive System
- Motor = TranzX PST 250W 36V brushless high torque front hub motor
- Sensor = Intelligent TMM4 torque sensor matched to an RPM sensor
These outputs are typically going to be combined to determine the human power input (torque x rpm = power) which will be applied and scaled into assist by some proprietary algorithm.
A. The rpm sensor can only be one of two simple types using either one or two halls - I'm guessing two so the controller can detect backward pedaling. This could be faked without too much difficulty with a bit of electronics.
B. The torque sensor is a TMM4:
idbike.com said:
TMM4 torque sensor - http://www.idbike.com/index.php/sensors
- TMM Sensor Unit (hall-based)
- Supply voltage: 5 V
- Output voltage: 1 V- 4 V
So - to trick the controller into working entirely from a throttle you will need to generate these two signals (rpm + torque). This is certainly doable, but not an off-the-shelf solution.
The best you might try for a quick fix is to replace the torque sensor with a standard hall throttle. The torque sensor spec shows this to be the familiar 3-wire 5V power 1V-4V signal as with any common hall throttle. This would let you fake the
pedal effort with the throttle but you would still need to at least faux-pedal to activate the PAS algorithm. This might be workable - you wouldn't need to exert any force, just keep up the cadence and adjust the fake 'human power' with the throttle.
Frankly, the first thing I'd try is contacting the bike folks and check if they have a throttle-only controller version. This would just be a firmware change since the basic unit already could accept a throttle input via the torque sensor input (electrically anyway). They might have something on the shelf that isn't offered commercially if you talk a bit about a medical condition, etc... Anyhow - might be worth a try...
