I would just like to clear up some confusion regarding the cell sizes.flügelwagen said:I'm considering purchasing some 15Ah 38120 cells from them and wanted to know if anyone has had experience dealing with them.
Thanks!
Hi Miroslaw. Since you like the threaded terminal design you can always buy the green PSI cells from AndyH. I am sure he will provide you with just as good a level of service as I have in the past. These are still available and I am sure they will keep manufacturing them for quite some time yet.miro13car said:Armin is the rep for LifeTech.
I was dealing with him and believe me he is very reliable person, imagine he sent me BMS boards made by New Energy used in HPS packs BEFORE I sent my money through Pay Pal.
I was in the middle of reconstructing HPS battery pack when I destroyed BMS BOARDS and I put all hope in Armin, BMI rep at that time. I was not dissapoined.
HOWEVER,
oryginal so called grey cels which he was selling and which are performing so well in my pack/2 winters, 2 summers/ are discontinued.
I understand present cells sold are designed by Headway and was initially made by Headway, or by opinion of some members are still made by Headway.
LifeTech cells are identical to Headway.
Use your own jugment and resoning.
MC
Feel free to email me directly so I can send you the complete battery product listings which show all of the pack weights and dimensions. I have a 36V 15Ah pack due to be shipped from the factory in about a week. This pack is a special pack which has been made up with a full BMS rather than the regular VMS which comes fitted as standard to the LiFeTech XPS packs. In addition we are changing the design for all of our smaller packs which will all soon be made using DuPont Xytel plastic cases rather than the aluminium cases which we have been supplying up until now. For a small pack the aluminium is quite heavy and adds considerable cost to these small size packs which is why we have decided to go back to the original plastic cases. In addition the factory must order 5000 cases at a time from the aluminium extrusion company which supplies the custom made cases. Of course all of the larger packs as used in EV's will continue to use the stronger aluminium cases but for small batteries the extra strength and cost for the aluminium is just not required.chroot said:How much the pack 36v, and 48v on 10 Ah and 15 Ah. I am curious, I am saving up some money for higher quality cells.
40138 Cell Assembly Blocks
These lightweight assembly blocks are designed to hold the cell securely while protecting battery pack wiring. They provide an air gap between cells that assists with cell cooling.
Two required per cell
Use 45mm copper straps (strap_45) for connections.
I don't, but lol...flügelwagen said:I saw on this board that they had these killer hexagonal cell holding blocks. Unfortunately, they can't sell them to me w/o the cells in the quantity I need. Does anybody know of another place I can get these?
MitchJi said:Hi,
http://www.rechargeablelithiumpower.com/oscommerce2/catalog/40138-cell-assembly-blocks-p-35.html
http://www.rechargeablelithiumpower.com/oscommerce2/catalog/pack-accessories-c-24.html
