From my experiences using 20" wheels and hubmotors:
The 9C from ebikes.ca (just unused rotor and spokes and rim, from Dogman, used with my own stator/covers from a previous 9C): Spokes were 12g, I think, and too thick to stretch when tensioned, so they wouldn't stay tensioned and just loosened and broke and fell out of the wheel instead, in an extremely short time. Rim was same Champion brand I'd already had in the preivous wheel, just in 20" instead of 26", and it's not a very good rim at all. I don't recall the spoke length needed, but it was radially spoked. I think I lost four or five spokes before I gave up on it as unrideable, set it aside to fix it and got it partly relaced with used spokes but never got it back onto the bike to retest before the house fire.
The HS3540 from ebikes.ca, prelaced with I think 12G or 13G "china" spokes, on whatever rim they come with: Again, too thick to stay tensioned, and they again just loosened and broke and fell out of the wheel. I forget exactly how many, but I think 10 (ten) spokes broke very very quickly.
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=12500&start=825#p752291
This wheel I got a new set of Sapim spokes, 13G I think, from Grin Tech / ebikes.ca, cut at two different lengths. Drive side is now 1X and left side is still radial. So far I have had no problems with the spokes loosening up or breaking, in what is at least 400 miles of work commutes and other riding, and that includes several SERIOUS pothole hits I couldn't avoid, 6-8" deep, enough to almost cause me to crash (the rear wheel, this one, has no suspension and has most of the bike's weight on it).
But to use the 1X, with my rim and these thick spokes, I had to bend the spokes prior to the threaded part, so they'd not end up snapping at the threads--this isn't desirable, but the only way I could reasonably do it without other special parts/rim/etc., using just what I had already plus the new spokes.
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=12500&start=825#p763615
I think it would be better to use double or triple-butted spokes, but I'm not sure how available they are in lengths as short as are needed for this kind of wheel, especially in a radial lace. I'm also not any kind of expert on wheelbuilding, so those above with more expertise and experience at it would be wiser to follow than me.
If you go for 1X instead, the wheel will be significantly stronger than radial, and with longer spokes might be easier to get the other spokes for. The catch with non-radial lacings in wheels this small with hubmotors that big, is that the rim's nipple holes aren't angled for this, so you may have to get washers for the inside of the rim that are made with "cups" in them so the nipples can be angled to allow the spoke to be straight, and not have any part of it that is bent. There are also nipples that have a matching curve to those washers, that would help with this.
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=22800&p=767501#p767501
If you still have the Champion rim that the 9C typically comes with, you might wanna change it out for a better rim that has eyelets, too, and a non-deep rim is better because you can fit longer spokes, making lacing easier and giving more ability to tension the spokes properly, and more spoke to stretch as needed on bumps/etc.
Brand of spokes: Sapim, PhilWood, etc., are all good ones. Probably if they *have* a brand name they are probably good spokes.
(though some are probably still better than others, I don't have the experience to say).
