el_walto
Has anyone on this forum actually got 500+ cycles out of an ebike lipo pack?
Ykick said:I really dunno what to expect when they die? I assume they'll just sag really bad and maybe puff?
el_walto said:Ykick said:I really dunno what to expect when they die? I assume they'll just sag really bad and maybe puff?
I've also wondered about this. If one used a lipo pack with BMS for 3000 cycles, would it gradually reduce its capacity to %5 and still be "safe", or after enough cycles would it eventually blow itself up?
grindz145 said:Capacity is probably going to be less than 80 after around 350-400 cycles.
liveforphysics said:This is truly something you can't generalize, the difference between some ebay RC packs and stuff a Tier1 EV provider is using is just a massive massive difference in lifespan.
SamTexas said:So where do Hobby King RC LiPos fall in that range?
Arlo1 said:I got 440 cycles on my turnigy 6s5000mah20 packs before I pounded mine into the ground <1v on high load on 2 or more cells, and now I got two cells that are overcharged very fast and go dead very fast, but I must say.
MY LIPO LASTED GREAT UNTILL I frocked UP! AND MY LIPO WOULD STILL BE >80 CAPACITY IF I DID NOT frock UP! Non the less i got some of methods miracle lvc hvc boards on their way!
liveforphysics said:grindz145 said:Capacity is probably going to be less than 80 after around 350-400 cycles.
That's a really hard statement to make these days, some LiPo technology is in the 10's of thousands of cycles at 95% DOD to 80% capacity. Some LiPo is as poor as 50cycles of only 80% DOD to 80% capacity, and it's just awful performance for that 50 cycles.
Dude this was my first ebike. I dont even own a lipo charger. Just 2 350w meanwell clones and some HK 3in1 battery medics. And other then your bikes this was the only hub motor bike luke was even happy with! Im ok with wrecking the first set of lipo as long as I learnt from it!John in CR said:Arlo1 said:I got 440 cycles on my turnigy 6s5000mah20 packs before I pounded mine into the ground <1v on high load on 2 or more cells, and now I got two cells that are overcharged very fast and go dead very fast, but I must say.
It sounds like you really beat them with a belt or a chain and sprocket instead of "frocked them up".
i'm on 569 cycles with current pack (made up of 5s Turnigy 20c) which, by god, is almost exactly a year old! i've been balance charging to 4.16 1x/wk and bulk charging to 4.08, and probably 5 times have let the cells dip below 3V under load.el_walto said:Has anyone on this forum actually got 500+ cycles out of an ebike lipo pack?
