Hi spinningmagnets, no issue here I think - AirStream said it's the law, but there's no way it is - there are eScooters all over the place and half the riders of them probably can't put them through one pedal revolution (well if half of them still have the pedals on that is
). Very heavy things, I tried one out and I got a few feet pedaling them, but it was a ton of work. The only legal requirements is that it doesn't go more than 32km/h on motor power alone, the motor has a max rating of 500W, you must be over 16 and wear a helmet and it must have working pedals. So I think I'm good with both throttle and PAS - will keep my ear out though incase that ever changes, thanks.
It's definitely nice having the Throttle/PAS power button right on the handlebar - it's so easy in my noobness to accidentally give it a turn and it's a mess.
It took me about 2 hours to come home today - about 30 minutes more than transit - but I went the wrong way for 10 minutes (I thought those other cyclists knew where I was going so I followed them when my map got fuzzy
) - but besides that it was a ton of fun to be riding the bike. I found 90% of the time I was on full throttle, so probably cruising around 23km/h on flats and faster the rest of the way. I wasn't very efficient, not at all - I'd start with the motor from a dead stop almost always. So of course, the dealer said 55km no pedaling - and I did help it a bit on the hills, but let it do most of them itself to see if it could make it. Almost got home, only 2 km away out of my 23km route -
and the battery just died. I could turn it on and use it for a few seconds and then dead again. Unfortunately, I was just coming to the hilliest part of the whole ride, almost entirely up hill and very steep - so I had to walk the last 20 mins or pushing my brand new ebike along beside me.
I think maybe the battery ran out of power - but all the lights were still lit, saying it was full. The bike would go about 2 feet with me on it, or it would spin in the air seemingly infinitely - I think maybe the amperage is too low. It read 36.7 on the voltage meter - it's a 36V battery - so that should mean it's got lots of juice left right...?
I'm wondering if the guy just charged it once when he got it a couple of months ago and since it was already 60% charged from the factory, he saw it only took 1 hour and a bit to charge and thought that was it and so advertised it as a quick charger. I topped it up another hour and a bit at work before the bike ride home - I'm not too surprised it didn't make it all the way home 23km with hills 95% on throttle alone - but I wish the indicator showed it was running low. The green would go off if I was going up hill, full throttle, but it always came back on right after - and the yellow and red stayed on always. Does the battery need conditioning and the display need calibration?
One of the things I wanted to ask - when using the motor, I find that at full throttle on level ground I can't do anything whatsoever to help the motor out - my pedals just turn like there is no tension at all, turning freely with almost 0 effort. Is there any way to adjust things to make it harder - this is on 6th gear. Though possibly, my gears are messed up - when I went to first gear again, the chain came right off again instantly. Either way though, is such an adjustment possible? I can help the motor with climbs and so on and I suppose I can try to run it at a lower speed than max (which is tough without the PAS - and maybe even with it!) - but it'd be nice to be able to make it home without having to turn my bike off much the rest of the time.
So lots to get fixed, not sure if I'll be able to make it to work with this thing - definitely though going to dress to work out and possibly sweat though, rather than risking it in the dressy clothes... Was so close too.
Peter
