999zip999
100 TW
My new 1220 shows I.R. for ea. Cell.
Interesting. I'm pushing them to 3.3V, 39.6V for the pack on the premised that 80%<SOC<20% will extend the life of the pack. Certainly never above 3.6V for sure.999zip999 said:Yes Ark I like a low end voltage as I find 3.45- 3.5 to be full. And get very little at 3.6 or 3.8v to worry about. But my pack is 20ah or 17ah if I push it out of the A123 20ah pouches. I due believe in A123...
Just the cells 100 x $8.75 per. Everything else was from materials on hand. Oh, and the digital soldering station and flat tip for $60. My first battery build was an experiment. This build is hardly that and expect 5 years. So maybe $0.60 a day roughly including electricity. What does a car take these days?Jason27 said:How much did this battery building experiment cost you arkmundi ?
for 2013, $9,122 a year on average according the AAA study, or $25 a day. http://newsroom.aaa.com/2013/04/cos...ording-to-aaas-2013-your-driving-costs-study/arkmundi said:... So maybe $0.60 a day roughly including electricity. What does a car take these days?
No, just pack resistance, initially, but if you watch which cells it takes longer to balance, and immediately after charge for all cells that is with the 5.82 firmware update999zip999 said:Winerboy your 1420 justs shows pack I.R. ? 1220 shows pre. Cell.
arkmundi said:I considered, am still considering the older B-grade and discounted cells at A123 AMP20 Cells, new, legit, factory direct!. Erik is offering those for $4 per, with the coupon ANR26650M1A-BGRADE for 100 or more. He's a certified shipper of lithium and will ship anywhere in the USA. Not sure about over-seas, so you might want to check with him - erik@evdmcorp.com. Shipping costs were very reasonable.
Yea, I don't know. I don't think it has to do with the nanophosphate core, as its all the same whatever the format. I think it may be that the cylindricals are pressure constant. Those AMP20s have to be built into a pack with the right pressure packaging, and I never got that part right. But yea, my AMP20 pack needed periodic balancing.docnjoj said:Perhaps (no doubt) those 26650 cells are higher quality than the AMP 20 pouches I got a year ago. However I need to use the 1220 balance charger after each 20 mile ride. I only use about 12 AH for these rides. but the cells really need balancing each time. With balance they are within 1/100. Good enough for me.
otherDoc
In total. Its 8 strings of 12S. The celllog monitoring and Thunder balance charge is for one 12S string. Repeated 8 times.999zip999 said:I don't see how you can balance charge with a 1220 or put a bms on your pack build as 12s8p. I can't see how a cellog type meter would work.
If it was built as 8p 12s you could balance charge and or bms and cellog. Easier to monitor.
