Lebowski
Arlo1 said:the motor is a SOB to spin by hand.... Maybe I can set the current limits low in Drive 2? What about this... I did discover with your chip there is a lot of times when the igbts get very short on and off pulses... Can we add limits for the shortest on and longest on pulse and shortest off pulse?Lebowski said:Ehm, no disrespect meant or anything, all in good humor etc, but, eh, so far you're doing a good job of proving me right....
A double pulse test is not the same as a continuous 5 kHz pulse train.
I get that but I can write code for a continuous 5khz pulse if you want and prove you wrong that way does that work for you?
If you want to make it easier to run sensorless (as you only want this to calibrate the halls), what you can to is spin the
motor by hand before giving throttle. The controller will then get in sync with the spinning motor before you apply throttle (phase current)
see the reply in the other thread.... use the % setting in the control loop coefficients menu
