Lebowski
you will need snubbers !
How much you want to bet?Lebowski said:you will need snubbers !
If I find I need them I will put them acroos the traces on the bottom.bearing said:The bonding wires inside the FETs have enough inductance to cause ringing. My guess is that your FETs have a ~10 nH per leg. Even if you don't think you need snubbers, you should at least put the components in the layout, to be able to mount them later. I would use a 2512 size SMD resistor (since they typically handles 2W, and a 0805 size capacitor. If you have big fingers, you could use a 1206 size capacitor instead.
Arlo1 said:How much you want to bet?Lebowski said:you will need snubbers !
So you run them in series? So you would put 12v to the three giving 4v per gate? They wont even turn on....circuit said:Um, all gates in parallel?... This does not smell right to me![]()
circuit said:Um, all gates in parallel?... This does not smell right to me[/qoute]
Agree, better to use multiple gate resistors
Not what I have been taught, its better to run 1 gate resistor so things are more even!Lebowski said:circuit said:Um, all gates in parallel?... This does not smell right to me[/qoute]
I do understand you can get slight differences in fets. But it is best to run from one gate resistor if you can. I will see how it goes. As well I will fet match per set of three as Jeremy and a couple others have.circuit said:Read on miller effect, also on distribution of miller capacitance and voltage thresholds among mosfets. No two semiconductors are identical.
With no resistors you may get strange ringing and blowups.
Circuit when you see what I am trying to run for a powerstage and how my plan to lay it out is you might understand why I laid it out this way.circuit said:I think you should not use an autorouter in application like this. Component placement is also very important.
Not yet. I had one good one left from the old batch that had all the settings I needed. I will be using them soon I have 3 new brain boards and 4 powerstage boards coming.Lebowski said:Are you using the new v1.1 i sent you ?
