If there is enough interest in this configuration, we may be able to get it added to their catalog. Here's the competition:
Leafbike 1500W
pro:
Strong axle
Thin 0.35mm lams
35mm wide stator allows 7-speed freewheel
con:
No option for aluminum mass in stator support
Factory wants to sell direct, no bulk purchase dealer discounts, which results in no US-based dealer.
Crystalyte H35xx
pro:
35mm wide stator is the widest available that still permits a 7-speed freewheel
con:
High power + regen + jumps = broken axle
Thicker 0.50mm lams
If you want aluminum mass in stator support, they want you to buy more expensive "Crown" series motor, but no option for Crown 7-speed
MXUS 1000W V2
Pro:
Thin 0.35mm laminations
Thick aluminum stator support as a heat-sponge
28mm wide stator easily allows 7-speed freewheel
Con:
Stator could be wider and still allow 7-speed freewheel that still "drops in" to common 135mm drop-outs
What I'm suggesting
MXUS 3000W V2 has room for 2-speed and 45mm wide stator, most use a single-speed freewheel
Factory can take a 3000W V2, and narrow the stator "just enough" to fit a 7-speed freewheel (35-ish mm wide stator?). Would have thin lams and aluminum stator support, 3000W axle and phase wires...the factory already makes a 35mm wide magnet rim, so...they already have all the parts on the shelf.
Leafbike 1500W
pro:
Strong axle
Thin 0.35mm lams
con:
Crystalyte H35xx
pro:
con:
Thicker 0.50mm lams
MXUS 1000W V2
Pro:
Con:
What I'm suggesting
