Uh oh! The meter on my trusty charger has just started reading in square blocks! Occasional numbers. Could I use my new Whattmeter to tell watts going on. Would I put it in series or // with the charger? This is for Nicads or NiMh only. The charger cut off and charge cycle work fine!
otherDoc
I use my watts up meter all the time with my Battery charger.From the charger out to the "source" side of the Watts up + to + and - to - then the "load" side of the Watts up to the battery + to + and - to -
Edit: as long as the voltage doesn't exceed 60 volts for the Watts up meter
Thanks Jozzer! I did and they said to mail it in! I know their customer support is quite good, but I cant give up my only Nimh charger until i get more batts!
otherDoc
