Hi.
Base for my build is ATV Adly SuperSonic 50
www.1000ps.com
The previous owner hasn't used it for the last few years, so there will be a lot of work to refresh some key elements
It is factory fitted with 50 cc engine, but frame is identical to all chinese constructions with motors from 50 to 300cc
Dry weight 155 Kg looks promising.
The vehicle has to be as light as possible, I don't need range. 1 hour of fun is enough for me
Since this is my first build, I have limited my budget to around $2,000.
After disassembling the machine and measuring the available space for the components, I started looking for a suitable battery.
The choice fell on NCM cells from LG, model P41 (used in VW qroup electric cars)
Below is the single cell spec.
Battery will consist of 20 cells in a 20S1P system
These cells have aluminum and copper connectors, so connecting them in series requires specific connection methods.
I chose the method, using FR-4 laminate sheets, rivet nuts and aluminum flat bars that press the cell joints together.
All cells, after assembly are glued together using Super RTV silicone from Wurth
For BMS – ANT 400A (1000A)
Battery is enclosed in an aluminum casing.
200A rated, 8mm bolt battery ports
Battery is tightly fitted inside using Armacell elastomeric foam, wires inside are 25 mm2 (AWG4)
Battery and Driver connection cables are 35 mm2 (AWG2)
Fuse housing MTA art. 0301502
I bought a relay (SW181 72V 200A DC switch ZJWH200A) but I was surprised by its weight, size and the fact that it heats up so much during operation that you can get burned.
I don't install it.
Currently I have everything wired up and I am starting to have fun with programming the controller.
I bought the whole set from SIAECOSYS.
I am not convinced that the controller is pre-programmed to work with the QS138 engine.
Below are screenshots with the initial settings that I made while studying other threads and guides on YouTube.
I would be grateful if you could find the parameter that I have set incorrectly
I don't know why the program doesn't read the driver version and its software.
For now I tested the work on the stand without load and the drive works smoothly.
I think that next week, I will put it together enough to do some test drives.
How it looks now:
Adly SuperSonic 50 2016 - technical data, prices, reviews
Find prices, reviews, technical data and availabilty of Adly SuperSonic 50 2016.
Battery and Driver connection cables are 35 mm2 (AWG2)Fuse housing MTA art. 0301502
I don't install it.
How it looks now:
