stan.distortion said:Great project and thread, subbed. Good luck with it, very interested in how it's working out in the hillclimbs.
All electronic driver aides are banned in my sport unless it was a feature delivered standard in the car through mass production. I built my car in 10 months on very limited budget. One of the reasons I was able to do that was because I opted for simplicity. I do have torque vectoring, but it is manual through my samurai sword handle. It has two master cylinders. If I push it forward it sends more torque to the left wheel. If I pull it back it sends more torque to the right wheel.stan.distortion said:Did you look into torque limiting/traction control? Makes the case for 4 independent motors and controllers, a leapfrog ahead of infernal combustion 4x4. The WRC cars are an example, the damn things can almost do ballet thanks to their traction control systems but they're limited to operating brakes and clutches on a conventional drivetrain, they can't have one side charging the batteries while the other side pushes around the corner.
EDIT: Electronic gear changes could be a winner too, they've got a bad reputation but that stems from cutting edge tech, F1 and WRC. Smacking a syncro box from one gear to the next at about the right time would be a lot simpler than millisecond changes with a dog box.
stan.distortion said:Cheers for the reply and sorry for the terse post, was rather drunk at the time and thinking out loud. Also read through kiwiev's Sonic thread earlier (hot damn, I'd sleep with that car!), dual motors on that one and had a mish mash of thoughts on the possibilities. Not sure how the "standard car" points in the rules would apply to yours but makes sense to keep the traction gizmos out of the sport, could quick turn into "he who pays, wins".
How come you went for and aft with the independent brakes? Seems counter-intuitive, impressive to see what folks can do with them in mud plugging (sporting trials) but there doesn't seem to be one "right" way of doing them, all kinds of variations in use. And had you considered going direct drive (no gearbox) or would that leave you short on higher speed events? From what I gather DC motors pretty much need the gearbox for road speeds, would've thought variable commutator timing could widen out the rpm range but don't seem to see it used much.
Thanks again for documenting everything so well, great read and really helpful for seeing the kind of pitfalls that can come up![]()
