Ok so first off, I have a 52v battery attached and I flashed the controller with the open source firmware. It has been working fine for many months but recently started cutting out. My display doesn't read voltage, so I hooked up a watt meter between the battery and motor and then taped it to my handlebars so I could watch it. I had thought perhaps the firmware had become glitchy and the LVC was messed up. Yet on the volt meter I watched it drop to 49v under load, rise up to 53v as speed increased, then it would cut out. Importantly, when it cut out the volt meter stayed on, meaning the battery was not cutting out. Only the controller was.
I would assume if my controller was bad, it wouldn't work at all. Not work flawlessly down to 53ish volts then...get tired and stop working. I'm hesitant to try reflashing the firmware since there is a risk of bricking my bike and I use it to make money, I can't afford any downtime right now. Maybe there is something else I am missing?
