Postby Ade » Tue Nov 03, 2015 5:26 pm
speedmd wrote:
Wet / moist conditions? No signs of wear? You lost me.
Sure they will last for some time with a well lubed clean chain, but for most of the folks that do not live in dry climates it is a non starter paying for a relatively expensive / soft sprocket if you are in mud often if there is a choice of a steel ring with the same offset. The 1000W has a bunch more torque than the BBS02 also.
Hm, torrential rain? Check. Snow, ice, slush and salt? Check. No problems here. Check.
I really don't know what you'd want. A steel chainring in the conditions I'd ride would be corroded - stainless would fair a little better with salt corrosion but would be softer steel so would wear more than plain steel anyway.
The fact is, alloy lasts long enough to be good enough, then, when you need it, you buy a new one. I mean, really, is $70 too much to shell out every couple of years?
Nakamura bigbob 4.0 Fatbike with Bafang BBS02 750W (100mm conversion), 10Ah bottle battery with 25R cells.
Ade
