robocam
- Joined
- May 29, 2014
- Messages
- 773
You can be our guinea pig =) Did you have chainline issues before the Luna Eclipse? 42T is the minimum for that kind of offset (in order to clear the gear housing), so this 36T chainring will probably have the same or similar offset as the Mighty Mini. I guess I shouldn't really mind what my chainline is as long as the chain stays on in all the gears. I wonder if too much slant can cause teeth wear.
I wonder why your chain wasn't happy with the chainring. And you're sure the wide teeth were in the wide slots and the narrow teeth in the narrow slots?
I'm thinking about getting the OneUp 50T cog to go along with the 42T chainring. That will be almost the same as my 42 and 38 setup right now. But if that 36 turns out to be ok, I might want that instead =)
Another alternative is to drop down to 26" wheels from 29". A 42T on a 26" would be the same as a 38T on a 29".
Dogboy1200 said:Wow! That looks sweet. Wonder what the offset is? Think I might have to try one. I'm currently running the Luna eclipse. I had some trouble with it at first. I had to shorten all the teeth a little so it wouldn't suck up my chain.robocam said:Has anyone tried this 36T chainring on the BBSHD?
http://precialps.com/uk/accueil/31-plateau-decale-36-dents-bbshd.html?live_configurator_token=61b1d9c574c5dcbddd1f63d9849834a6&id_shop=1&id_employee=1&theme=theme2&theme_font=#/11-couleur-noir
