Bafang BPM code 11
gabriel
Hey there!
I thought about motors and found out a bafang code 11 would fit my needs perfectly.
Does anyone know, where I can get a cheap BPM code 11(280 rpm) shipping to AUSTRIA?
I thought I'd need a 500W motor, but Sam just told me, they are all the same, so I guess I can take the 350W one on elifebike right?
(http://www.elifebike.com/peng/iview.asp?KeyID=dtpic-2013-4R-S0X6.9P4YV)
The 350w can handle less power than the 500w one. Choose it if you want to run 22 amps or less. It's the same size and weight as the 500w one, so get the 500w one if you want to go over 22 amps. Hardly anybody sells BPMs by code numbers. Instead, they normally give rpm, though you can never be sure that the rpm is correct. When you find one with the correct rpm, you should ask the vendor for the code number to be sure.
Oh I thought they are built exactly the same, just labeled differently.
I'll need to run it on 25 amps, so I found a different offer:
It's a 500w code 10 (300rpm) which would be fine!
Only thing.. it's a 36V - does that matter?
