I have four questions:
1. I would like to replace the larger case bearing of a Bafang BPM 36V500W hub motor. The bearing assembly has disintegrated and I'm not sure how to extract the remaining parts. Could anyone suggest how to remove this?
2. Does anyone know the bearing type for this so that I can order another?
3. The smaller case bearing seems OK but it may make sense to replace this to. Can someone suggest the type and how to remove?
4. the whole motor assembly was full of mud. I will replace the clutch and planetry gears. I'm wondering how to make sure the motor is properly sealed from water ingress because this motor does not seem to have seals to prevent this.
