hi all,
i've got a boardman full sus with the battery mounted on underside of downtube (which i suspect may have led to the issue due to getting all the road crap thrown at it, even with a cover).
Bafang HD motor and Hailong 20ah 52v battery.
Last week it just died during use, no power at all. wouldn't start up from the button, power cycling the battery with battery toggle switch would sometimes let it start, though this often wouldn't work for minutes on end. lots of switching battery off and on, trying power, battery off and on, power switch etc, then it would eventually start, often to die within seconds, especially if under load.
i took battery off and connections were really crappy, opened battery and cleaned that up, got a new battery baseplate after cleaning them up and problem still there.
got multimeter on it today, with battery switch off, it measures 3.4v, with battery on it's 56v.
i could make it fail within seconds by putting it under load, full throttle in driveway and it would die almost instantly. it deffo is load related, as i was using it for work earlier (after thinking it was fixed, it had done 3 journeys of 15 mins after cleaning up connections, and all SEEMED fine), and on PAS 1 it would stay on, pas 2 or 3 and it would die.
when it dies, i've slapped the meter on battery outputs and they show 3.4v, even with battery on. after one or two toggles of battery power rocker, it usually then outputs 56v, plug it back into bike and it'll start, but again fails within seconds if under any sort of load.
i suspect maybe the battery BMS is faulty, though any advice would be much appreciated. Inside of the battery was dry, no damage at all, but the battery and baseplate connections were utterly awful, pics attached. maybe this has shorrted something out in the BMS ?
weird in my mind that when i cleaned it all up, it then performed with no issues for 3 15 min journeys (mix of PAS 2 and 3), then became unuseable again.
thanks for any advice,
cheers,
col
cheers,
col
