Bafang M600 throttle addition?
The throttle doesn't connect to the display but rather the cable the display plugs into. Trace the display wiring back and see where it plugs in, your bike might not be equipped with the cable that has a throttle input. I hope this photo helps clear up where the throttle plugs in, if you need to purchase this cable GBK sells them: Bafang M600 M500 M510 M410 M200 M820 motor EB-bus Cable-greenbikekit.com BBS, ebike batteries, Bafang M620, Bafang M600, Bafang M500, Bafang M510, KT controller with display-GreenBikeKit.com 1719884745410.png
See, I had no idea. Thank you!
Do you think the thumb throttle above is compatible?
Yes I believe it will work just fine. Hopefully you don't need to get into the software to enable the throttle, but it doesn't hurt anything to test it!
