I’ve not been able to get a ride on a BaFang-equipped bike so am having trouble guesstimating the power output I’d get from their 350 watt system. About a dozen years back I had a Currie “Pro Drive” MTB with planetary-geared motor mounted on the left of the chainstay. I was told it was 450 watts, and it was strong enough to only need pedal assist on the steepest hills. My last e-bike, two years ago, was an iZip "Via Rapido". It was a pleasant riding bike, but its 250 watt hub-motor was useless on even moderate hills. I'm thinking that Bafang's mid-drive using the bike’s gears should be a very noticeable upgrade over those two designs.
75% of my commute needs no assist, so I’m hoping to take the minimalist approach to e-power and keep the motor/battery weight as low as possible. Speed is not a priority, I just want help cresting the local Alps [as much as 26% grade] without needing a shower. Would the Bafang 350 and 36v 11-amp battery turning a 32t granny on a 26” MTB with 170# rider be enough?
