Eisch13
- Joined
- May 17, 2020
- Messages
- 2
I have spent some time searching board for answers and I believe my bafang hub needs new hall sensors.
When I test for 5 volt signal between black and a hall wire with controller powered up I get a constant 5 volt on two sensors and a 0 to 5 on yellow when I spin wheel. I also have a white wire that pulses 5 volt.. I believe it to be a speed sensor...
It started with a burned up power cable between motor and controller.. motor leads overheating..
I have new cable and checked for continuity from hall solder points to cable that will plug to controller.. I think I’m good there...
Is there a circuit board assembly available to replace? Or do I just need new hall sensors?
https://photos.app.goo.gl/SM96K2EExVii6Nay9
