Hi all
One of my hall sensor wire didnt do good connection so I was moving the cable to see which one isn't working. Then the bafang stopped working at all ( before it was doing a weird noise when the hall wire didnt do a connection) . I replaced the wire but still the bafang doesnt work at all. I thought I burnt a hall sensor so I check the hall sensors and all read 5volt so they should be ok. Is there any possibility the bms went wrong ( from testing with a faulty hall sensor wire ) though the BMS seems to work cause I check the throttle voltage and it works fine ( so that means the controller is on ) ... I checked all the wiring and seems to be good..
Any help ?
Any help ?
